Victory
Well, it's almost exactly one year since my first post starting this thread. The crane is functional! This is going to be a really nice addition to my shop, whether for swapping chucks, or rearranging machinery. Well, Ok, rearranging some of the machinery, the really big stuff, the K&T 3K mill, the Monarch 612-2516 lathe, and the Tree 750 VMC are too big. The crane is certainly useful for working on those, just not picking the whole thing up.
Here's a
few seconds of video hoisting the cheap press. Yeah, I'm not a youtube cinematographer.
I load tested it, deflection limit hit at 4500 lbs. Design goal was 4000 lbs so that was good. I loaded all the way to 1.25x (5,000 lbs load). The granite table weighs ~7000 lbs, so it never left the ground. Dial indicator over the hoist point and over the bridge ends (3 all together). Orange thing above the chain hoist is a 6600 lbs rated scale. No load in this picture, so if you want to claim it didn't happen I'm not going to argue, lol. Of course you're not the one working under it!
The motorized hoist in the video, and on the right in this pic, is only rated for 2000 lbs so it wasn't used for this test.
The last detail was getting this coupling assembled and driveshaft aligned. Just a thick piece of rubber stall mat cut round and put between the two flanges. The driveshaft runs almost the full length of the bridge beam, about 21 feet, in two segements. This is right in the middle to give it a hint of flex. The beam deflects around 3/8" under full load, and the shafts are not precision straightened, so they're not going to run perfectly true. This gives a bit of flex while coupling the drive motor end (see above) to the opposite side truck.
I still have a some programming work. As you can see in the video, there is a cable running from the motor control cabinet to the remote. Hardware is there for a bluetooth or wifi connection between the two, I just need to code that up. (
Simple matter of programming, famous last words). And I could still do a bit of clean up, some zip ties that need to be trimmed for example. But it is now usable for around the shop chores, projects, etc.
Time to pour a cold one.
