- Feb 25, 2021
- 3,271
Jeff,Randal, I think you would be chasing your tail trying to level it with a machinists level. That's a lot of accuracy for something that will probably start deflecting and lose much of that instantly. Just an opinion. I do agree about keeping it loose until you get it all together, but you can probably start tight , then loosen it so that it's self constrained and as true as it will get without your further intervention.
I think 5 gal concrete pails a bunch of them with eyebolts in the concrete will be your friend in trying to setup and secure the iron. That, or some holes in that nice new floor.
Buckets would scare me, once things got to running away. There is a bit of significant pendulum mass so a little oscillation in the structure (imaging it bouncing around 1/2") could overcome static friction. Of course, I could guy wire it to one of my bigger machines. Rather than that, the current plan, subject to more pondering...
I ordered 4 eyebolts. I'm going to strap the rail to my tractor loader bucket using multiple tractor trailer binder straps. I have bunches of those from hauling hay. I'll use the bucket because that is a 6' width rather than the not quite 5 that the forklift attachment will span, and the forklift has a back guard that will interfere. I'll set an eyebolt into the ceiling into a 4x6 that spans 2-3 ceiling trusses. Not a rigorous analysis but each truss will hold my weight plus my wife's, which is one wife-unit heavier than the beam half (i.e., I weight about the same as one end of the beam). The beam will go up the loader and be bolted in place, and safetied to those ceiling eyebolts and bolted loosely to the top of the posts before the loader is removed. That gives me enough redundancy that I can then use the loader to hoist the other rail and start tying them together.
As far as the level, I'm not feeling like crunching the numbers to convert precision right now, but I don't think trying for level to within 1/4" across the entire structure (roughly 40' x 24') is that unreasonable. I'm not leveling it to within a few thou, but *guessing* the span and angle is getting within the same ballpark. I have a 6' carpenters level I'll start with of course. I'm not THAT stupid even fresh out of the hospital.
edit: .250" over 40' is .0062/ft. Not lathe leveling accuracy but tough with a carpenters level. I do have a carpentry laser level that could also used.
