So after clean up and inspection I noticed something maybe someone knows. My machine a BS h612 challenger. Circa late 70’s. I’ve read in earlier and my manual that as a option hardened ground and scraped ways. I’m no expert by any means but when I look at the “scraped” surface. To me it’s been ground and flaked. All marks are connected by the tail of flaking process. The pattern is crisscrossed and way to repetitive for scraping to me. I know I should post pictures but I’m not there now I will do so later. Any thoughts.
Another thing looking in the manual it says the vertical column is lubed from the oiling system. I cannot see a path that the oil would get to the vertical ways. Unless they use the bevel gear oil line and it just gravity drips through gear,and thrust bearing area eventually overflowing off plate and mysteriously finding its way to the ways????
Was just wondering for reassembly if I should put a thin film of grease on column then let whatever drip. Again any thoughts??
