Here is one of my Ruger 77 rifles in a Boyds stock. While I did bed it it was near a near-perfect "drop-in" and would have worked fine without any other work.
For Laminates, Boyd's is a household name. They sell a gazillion of them.
Another possible source- Richards Microfit- http://rifle-stocks.com/
I plan on using one of theirs for my Mauser project
Uhh....basically. Because it has two "military features" Semi automatic and thumbhole.
I'm not even allowed to sell it, even through an FFL because of this "safe" act.
:whiteflag::whiteflag::whiteflag:
I wonder if you could modify it to open the top of the thumb hole and make it compliant? It would feel exactly the same but would no longer have a "thumb hole".
I have fitted out a half dozen of these stocks. Mainly for Rugers, 10-22's and 77-22's. My complaints are all the same. The trigger reach is quite long. It could stand a shortening of a good half inch with no harm. My only option has been to open the thumb hole towards the trigger. Action fit is usually pretty good and easy to finish. I still pillar bed them with good results. Overall length falls into the 14 3/8" range and altered by adding a pad. Now the gripe. The laminate construction makes the stock virtually 90% edge grain. This edge grain does not seal well and soaks up finish like a sponge. I usually apply a couple coats of Benite wood conditioner with a good rub down after the second coat. Without a good seal a nice gloss/semi-gloss finish is nearly impossible by my methods at least. Second, all those lamination's make for a rough, wavy surface because the glue joints are harder than the wood making for ripples. Even after using a sanding block. With that knowledge I usually stop at the 220 grit stage and apply finish then. I have not tried a subdued oil finish or the like as usually the customer wants a glossier finish to show off the lamination.
And so goes the life and fortunes of a junior wood butcher.
Now lets get back to making SWARF!
I had a Boyds ventilated thumbhole stock on a Ruger M77. It was mostly inleted and not finished. It was very high quality and I had a lot of fun finishing it, I pillar bedded it. Unfortuneatly It was purchased from me by a friend. He said it was his most accurate rifle. 22-250 cal.
I thought of that, but because of the design I'm afraid it will be too weak by the wrist. Maybe one of these days I will modify it for my Benjamin Marauder air rifle. That will be legal.
Mr. Wilson, I agree with you. Really has that Enfield signature to my eye also. The silenced .45 acp would make for one heck of a walk around rifle. Really neat idea.
