I was turning at 45 RPM. My time is free-ish!
I don't think I have enough metal left to cut at the shoulder to run a parallel cutter (boring bar, drill bit) down the full length...only about .005" left in diameter due to the minimal taper of this cartridge. Maybe I should change to a 6.5WSM, that would clean up this chamber!
Jubil, there was a post earlier with a link to a thread at practical machinist. My procedure is basically identical. The tip of the dead center fits the center dimple at the back of the reamer to hold it on center, and a wrench (with set screw to hold reamer) on the flats prevents rotation. Advance the tailstock to advance the reamer. Hold the wrench in your left hand (to control, aim, and withdraw), advance the tailstock with your right. It is slow going, pecking at it, especially once the tailstock runs out of travel. Then I have to unlock and withdraw the entire tailstock each cycle.
Pontiac, I tried locking down the steady last night and made a few light (about .020" advance per cut/withdraw/clean/lube/restart cycle) cuts. At first it looked promising (based on layout dye removal at the peaks, not valleys) but the last 2 were not. I am thinking about some very light cuts, extremely tedious as it will be. I guess a slightly misaligned chamber is the least of my worries now.
