- Aug 6, 2015
- 4,293
Bruce ,Instead of trying to heat and bend a 90 at the top of the spring, could you drill/tap a couple of holes in the spring for threaded pins/bolts? If I'm understanding the action correctly, the hook at the top is a stop to keep the spring from slipping. Maybe accomplish the same thing with a couple of pins, or a stop block screwed to the spring?
Bruce
The bends at each end, several ways to make those, correct… but it is the main bend that is what I see as a challenge without heating it…
Thinking of just making something like this…
