- Jan 22, 2011
- 8,032
One thing not mentioned (unless I missed it....sorry if so) is what I know as a Post Processor. Short form: Post. Not the same as P.O.S.T. for all the PC nuts here. Is is a simple translation program that must be custom tailored to each machine control type. Some controls don't read every M and G code the same, or some not all the same set. So, if you have a certain control, say, a Fanuc 0T (oldie, I know), you have to run your code AFTER (hence the term post...) writing it, whether manually, or with some CAM assistance, to actually "fit" the control on the machine you want to run the program on. You can have the same basic source program, and multiple post processors make it compatible with any control you have. Some of this will not apply to home-brew CNC, but factory but controls require this treatment.
