- Feb 8, 2014
- 11,176
This is a stepper speed controller that does not require a computer for control. It has limit switch inputs but will not move a specific number of pulses.
http://www.ebay.com/itm/9-24V-Input...59466c&pid=100338&rk=3&rkt=30&sd=281570110066
Once you add distance traveled then you are into CNC control. Most if not stepper drives have several settings for steps per revolution and power output.
The down side of putting handles on the steppers is that steppers cog when turned and cause the hand feed to be ''lumpy''. The other thing is that the steppers become a generator when turned by hand and if connected to the drive, require extra effort to turn. For hand feeding you would want to provide a switch to disconnect the motor wires from the drive if the motor is mechanically connected to the lead screw.
A belt non-cog system would work on the Y and Z, also on the X for power feed, but for accurate positioning it would require a timing belt..
