I'm working on rehabbing mine (see earlier in this note), so I took the locks out and took a picture. They are Zamak. Notice that mine were not the same. I think someone put the washers in after the lock started to wear. I also found out that one of the lock handles is stripped. Helicoil time I guess.
Mine are kind of beat up. The measurements that I get vary among the parts.
1 Dia=.615-.621, L=.709, Hole is a snug fit on an F drill(.257), the un-arced part is 1/2", the un-machined part of the nose at the narrowest part is 3/8", the square hole is 25/64.
2. Rubber, so dimensions are difficult but it's about 5/8" dia, 1/2" long, and the hole fits a J drill(.277) It appears to be cut off tangent to the center hole.
3. All similar to #1 but no square hole, length is .711
4. Dia=.6235, L=.6565, hold fits an I drill(.272).
When I put 1 and 3 on the bolt and make the arcs rest easily on the overarm, there is 5/8" between the ends of the parts.
There are some problems with these dimensions. When I build a cad model, the arc that defines the two curved surfaces on 1 and 3 drops too deeply into the slot in between.
In the drawing, the blue lines are the centerline and outside of the parts, the yellow lines are the hole through the center of 1 and 3, and the green and magenta lines are used to construct the arcs. They suggest that the overarm will intersect the clamp bolt.
The rubber piece is 1/2" long, so I'm going to try a construction with that spacing. That will move the overarm away from the clamp bolt.
