In another thread I documented a new to me model 9a. Some wire photos are there that i dont have on my phone at the moment. Transportation issues lead to a missing countershaft pulley. When the replacement arrived, and I fired her up the motor sounded like it needed bearings badly. So after a quick function test seeing everything worked, and learning how amazing back gearing is, I took the motor apart, cleaned the case and replaced the bearings. I rewired it the same way it came apart and she runs so quiet and smooth now. I was able to verify correct rotation (CW vs CCW) by swapping leads per the motor diagram.
But now when I try to wire it to the switch, it runs for a few seconds, then blows the breaker switch. Reset the breaker, verify tight connections, turn on, motor sparks, breaker trips.....and here we are.
Previous owner appeared to have motor setup for "high voltage" as all wires primarily come off the 3 terminal. There is nothing but an empty square at terminal 2 as seen in the "no therm prot" diagram.
He claims never had reverse from the switch and was wired for 110 as I need to. I thought "high voltage" was 220?
Pic of wiring before removing everything to replace bearings. For reference the 3 terminal is where the spaghetti starts
Photo the previous owner supplied of how to wore the switch. Notice no grounding, and the thick gauge wire jumper for the middle and right terminals.
