So after half a night sleep something sticks out to me. I don't have a source for +12v yet, atleast spec wise on either power supply. The PU-110 was set to +12.19 on pin 8,9 and -12.35 on 11. Maybe Anilam was using this part outside of its specs, OR seeing how this board is revision K I wonder it that is supposed to be my 12v source.
The fella I bought the mill from said he talked to Anilam support and had adjusted the power supplys so the readings are at least in question.
What is still odd, and I will double check today, is that with everything powered on I got zero power indicator LED's in the console where I previously jumpered power before. With what seems like two channels atleast showing close to the correct power it would seem I have a common or ground connection issue between the console and control box.
I'm putting the PSU together this moring and if I feel well I'll go out and trace some wires to see if I can determine if that channel is supposed to be 12v or 15v.
Thanks for following along! Hopefully I'll get to make chips on this thing in Febuary.
On a side note if anyone spots a good deal on a Kurt D688 or a pair of 4 inch kurts let me know. I just missed a 30% sale with free shipping at ENCO and I'm on their mailing list now.
