Little progress today. Looks like I have some power supply issues. I think all can be rectified by just swapping in the ATX.
Heres my findings
PU-110-32a
All readings are with no load
pins 1,2,3 to 4,5,6,7= +5.76V spec +5v
pins 8,9 to 4,5,6,7= +13.8V spec +15v(I did adjust this as high as possible, low range was 9.8, best I could get was 13.8)
pin 11 to 4,5,6,7= -13.8V spec -15V
PU-30-32SL
1,2 to 3,4= 5.13v
5 to 3,4= -14.05V spec is -12V
6 to 3,4= +15.05V spec is +15V
I'm not sure what pins are used off these, but both are pretty far off and wont adjust into spec. Each board only has one pot for adjustment, like only one channel can be adjusted. Maybe this one pot effects all channels?
So the first thing I see looking at swapping in the ATX is that is does not offer a 15V channel. Open to suggestions on how to solve that for close to free. I looked up these two boards and both seem obsolete and around $500 bucks at that.
