- Dec 18, 2019
- 7,495
Went with 5mm rivnuts. Got two of them in, enough to hold up the box. Used the technique in the previous post, and drilled through the box and straight into the lathe stand. Then I removed the box and drilled out the holes in the stand to the correct size. That was a M drill. One of the rivnuts needed a little pursuation to insert, but managed to do it. I seem to not to know when to stop pulling on the rivnut. Managed to pull out the threads of one! So I had to drill it out and put in a new one. Wasn't hard to do. Need to install a third rivnut, but that will be for another day. The rivnuts are in an inverted L pattern.
With the box mounted, it is starting to look like I meant it, rather than a total mess. It all powered up and nothing exploded, so that is good.
Started looking at the cover to the pulleys and former gear chain. It turns out the very bottom of the cover fouls with the stepper motor pulley. I marked it and will cut out a notch in the cover. I will probably make a little sheet metal guard over it all. Lord knows how I can do that, but somehow I will muddle through that. I need to make some other cutouts for the cables, but I think that won't be too hard. I will use cutoff disks to cut the metal, it is steel and too thick for my hand nibbler to get through. If I really squeeze hard I can cut off a piece, but it is too tough to use continually. If I had a power nibbler, that would be different. The cable holders I got are just a little bit loose. They allow the cable to slip. While great for adjustment, it is not good for vibration. So I will have to wrap the cable with something so the rubber will grab it.
I will get back to the display box in a couple of days. It was frustrating me so much, that I needed to avoid it awhile.
