Been staring at the boxes (cases) today, pondering the packaging and bezel problems. I can see that I can fit this in a box, only if I lower my Teensy. It's currently in a socket, which elevates the part high enough it just hits the bezel I designed. If I solder it in place, or find a lower profile socket, it will be fine. I only need a mm or two more clearance. The sockets I have are 8.5 mm high female headers, and the Teensy has 6 mm pins. Maybe I can solder the Teensy into the board with some low temp solder, so if I have to remove it, I have a fighting chance. The Teensy is a 2 x 25 pin device DIP separated by 0.7", so it's kind of hard to free up all those pins at the same time.
