- Jan 20, 2018
- 5,869
Cutting those little pieces the way you are is probably the most painful way I can imagine, short of chewing them off. Parting them in the lathe would be preferable, and probably faster. Is that the only saw you have access to? If so, it's time to go to HF and buy a 4x6.This is the saw i have and the blade that is on it. The first set of things cut ok but once i got to the 1/2" material. I am having a hard time cutting the steel. It looks almost like it is work hardening as i am cutting. Is there a different blade i can maybe use? I still have 3/4 hex material to cut and i do have a 5/16 416SS pces to cut?
The use of any power driven abrasive (bench grinder, chop saw etc.) on aluminum is a no-no. There is enough heat generated that the aluminum will "melt" into the abrasive, requiring dressing off enough material to get below the aluminum.
