- May 27, 2016
- 3,477
They are called different things..
Hank bush? Rivet nut? Nut insert?
There seem to be fundamentally two kinds, and the serrated hank nut, possibly known as "nutsert", seems to be the most widely known. I now have need to use some on a car necessary brake plate shield modification. If I do have to buy a insert tool, I would hope to find it useful again in the future, and I don't want to end up with junk.
I have already made one mistake in buying some M6 nuts that are unwisely chosen (too big), and appear to need some kind of swage tool to mount them. Maybe, all they need might be to simply put them into the sheet metal hole and do up the bolt until it crushes the little flange? Perhaps I should mention that the nut I intend is made of stainless steel A2 (aka 304)
_ _
The other sort seems to come in a great variety of types, like "countersunk" and "reduced head". There are also all kinds of insertion tool types ranging from "pop-rivet" style through larger, longer handle versions, and various gadgets that are driven from a cordless drill.
_ _ _ _
One of the "driven" kind has a side handle, presumably to stop rotation.
The king of the heap (from eBay) is the red gadget kit at £40. With no side handle, it looks like one just grips it with one hand while working the cordless drill driver with the other.
I can appreciate the drill-driven types might make the job easier, but the first simple hand squeeze type looks able to get into a space where all the others could not.
I have never used these before, and I would appreciate any tips the folk here might have, especially if some kinds, in your experiences, are just a waste of money!
_ _
_ _ _ _
