- Jul 14, 2017
- 2,463
After few days of being very busy i finally had the night off, so i continued on the blue 206. First i reinstalled the back tires, dropped it down on the ground and install the exhaust. After that i fired it up now quiet and left it to run. With it running i decided to charge the A/C. First i vacuumed the system down, let the refrigerator motor run for more than an hour to remove as much of the air form the system. Then closes the valves and watched the needles for half an hour. It held the vacuum so i charge it. This small car takes more refrigerant than both Skoda's. Now with working A/C i loaded it up with all the tools i had bring over and transported them back to the big garage you can see how soft the suspension is it squatted down from couple of my tools inside. I unloaded it and began installing front wings and the hood. With them installed i called it, took a shower and went to work, it turn it to an all nighter.
