Couple of POTDs. First was cutting away some of the plywood base on one of my work benches. The storage lockers and maple top came from a local high school that shut down its shop. I wanted it to be movable without kicking casters hanging outside of the bench. I didn't show them, but used 1" steel balls used for material movement as low-profile casters. They're around $2 each from Harbor Freight; they call them roller ball bearings. I screwed a couple of rows of these under some 3/4" ply and mounted the lockers and legs to support the maple top. Problem was I couldn't "belly up to the bar" with my office chair. I used a Rotozip and a screwed down board for a fence to cut away a large portion so I can roll the chair up under the bench.
Cut away the 3/4" ply next to the lockers so I can roll the office chair up to the bench
Used these ball bearings for casters under the plywood base
Now what to do with the 3/4" plywood cut out from under the work bench. . . I have a number of coils of band saw stock for my DoAll saw and hadn't come up with a good place to store them. I repurposed the 3/4" ply for sides of a storage cabinet for the coil stock. Nothing too pretty as the plywood used was all scraps. Frankly, who wants to buy any sheet goods at today's prices!!! The dado's in the sides have a 1" drop from front to back though this is probably overkill on my part. I didn't show it, but cut a couple of lengths of 1" angle iron that was screwed to the sides of the cabinet for a mounting bracket. The brackets were screwed to the wall with 1/4" lag bolts.
Used 3/4" ply from the work bench base for the cabinet sides, 1/2" scraps for the top/bottom/back and 1/4" for the shelves.
Blade storage cabinet
DoAll 16" saw, my blade storage cabinet and welded up stock hanging above the cabinet
I have a buddy at work who picked up a lot of band saw blade stock from a closed shop. He presented me with a deal; cut the blades to length and weld them up for his Walker-Turner saw and we'd split the stock. I welded up around 40 blades for him, and was welding some for me but got tired of welding blades. I coiled up the stock cut to length, banded it with tie straps and tucked it in a few of the shelves.
Thanks for looking,
Bruce
