Caught up on a few things I've been wanting to get to. First was a 12" Delta sander that I got from a pawn shop a few years back. It was wired for 220, so I couldn't test it in the store, but I figured the motor, which looked to be new, was worth the $100 I paid for it. Hauled it down to the shop today, and ran some juice to it. Switched it on, and it started doing the shimmy, like Ann Margret dancing across the floor. Checked it for run out, and it had about 1/4". Put the disc in the press and got it straight, and then chucked up the hub, and faced off about .060 to get it trued up. Runs pretty nice now, but I think I'm going to pull it back off and static balance it on a setup I made years ago for motorcycle wheels, to get the last little bit of vibration out of it. The next job was installing the pulse width fobmodulater/rheostat on the mag drill, and reworking the spindle attachment for the through spindle coolant. You couldn't turn the attachment on the spindle by hand, and the spindle was getting so hot you couldn't touch it after a minute of running with no load. The coolant ring had o-rings top and bottom, and when machined they had failed to chamfer the the ring on the two outside diameters, and the metal was even with the uncompressed o-rings. Faced off, and chamfered both ends. Next I wanted to tuchup the o-ring sealing surface on the arbor But I couldn't reach that feature with it in the chuck, so for the first time, I used the spindle taper on the lathe with a 2-3 adapter which allowed me to get it done. Reassembled everything with an added thrust washer, and it now works like it should, and I have variable speed on the drill. Sorry pics are a bit out of order. Mike
