I recently replaced my 12" Craftsman wood-cutting band saw with a 1948-model DoAll ML 16" saw. I love being able to change speeds quickly between metal and wood. I was replacing the threshold on a garage door at my parents house and needed to cut a 36" aluminum extrusion down to 32". Had to do some notching also (alas, no photos of that project). Not that it was super critical, but I wanted to cut the end of the extrusion square. My DoAll saw table doesn't have a miter gauge slot though DoAll offers this accessory:
The standard miter gauge bolts to the edge of the table. It looks to be a steel rod with end brackets. The miter gauge appears to have linear bearings for riding on the steel rod. It also looks like the miter assembly can swing around 270 deg. off the table when not in use. It'd be nice to have, but probably costs more than my entire saw.
Instead, I figured on extending the table with a piece of 3/4" x 3/4" and 1/2" x 1 1/2" CRS to give the saw a standard miter gauge slot. My plan was to bolt the 3/4" square piece ~0.390" below the top edge of the 1/2" thick piece. Then bolt the whole assembly to the 4 tapped holes in the saw table. That'd give the saw a standard slot for using the table saw's miter gauge.
I was too lazy to pull the vise off my Bridgeport and go directly to the table. I used an 18" long gauge block to verify the tram of my vise. I guess an alternative, since the holes were grouped together on the ends, would have been to just touch off in Y at the center of the hole clusters.
I supported the ends of the 2' pieces of steel with a machinist jack. Then center/spot drilled and drilled clearance holes. The DoAll table has 3/8"-16 tapped holes, naturally used a 3/8" drill for the clearance holes. I used 5/16"-18 cap screws to bolt the 3/4" square bar to the 1/2" X 1 1/2" bar. Probably not the smartest move on my part (lack of experience/confidence maybe. . .), but the three 5/16"-18 holes were power-tapped on the BP. Always makes me nervous though I think (hope) the tap would slip in the chuck before breaking.
Easy peasy after the BP work was done. Ran the 5/16-18's with a dab of Loctite to secure the 3/4" square piece to the 1/2" bar stock. Then four 3/8" cap screws to tie the assembly to the table.
Father's day is just around the bend so I anticipate getting (if my wife and kids check my Amazon wish list) a Kreg or similar miter gauge. There are a few out there with aluminum 80/20-type extrusions with sliding stops, etc. that should work well.
Thanks for looking, Bruce
Bolted steel bars in place. Gives the DoAll a 3/4" x 0.390" deep miter gauge groove for a standard table saw miter gauge.
