Thanks David. Not anything compared to your cnc plasma table, but gives me another project to work on. I've been accumulating blade stock and will need to store it somewhere/somehow.Really nice work there Bruce!
Bruce
Great idea. That'd be close enough if I go the digital route.@BGHansen - I just had a thought. You mentioned that it's a 16" saw. So I assume that means the diameter of the wheels is 16". A 16" wheel has a circumference of 50.27" - not too far away from 48". So if you put four equally spaced magnets on one of the wheels, used a Hall effect sensor to detect them, and told the tach there was only one tick per rotation, the RPM reading would be a close approximation to FPM.
I would not have thought of that, but you sure made it to be simple. Thanks.@BGHansen - I just had a thought. You mentioned that it's a 16" saw. So I assume that means the diameter of the wheels is 16". A 16" wheel has a circumference of 50.27" - not too far away from 48". So if you put four equally spaced magnets on one of the wheels, used a Hall effect sensor to detect them, and told the tach there was only one tick per rotation, the RPM reading would be a close approximation to FPM.
Had a busy day loading and hauling my latest acquisition.
Should we be expecting your invention output to be advanced by a couple of big loads too?
