- Sep 2, 2013
- 5,417
I dated a girl like that once. Mike
The hour meter is vibration activated
Found it Here on Amazon. Says it has a lifetime battery. Then in the fine print it says 2 years of battery so I guess it just means the battery last the lifetime of the battery .
There appear to be other options though that have replaceable batteries or plug in.
I like the toaster oven idea. I use a single 750 watt hotplate; put the parts on it and cover with a remnant from an aluminum pie pan. I use a spacer like a bent piece of copper sheet to keep the work-piece off the heating coil. Very crude, but it's easy and it works. With something like a chuck wrench, it takes ~10 minutes to produce a nice, deep blue color. This oxide layer looks nice, but it is not as thick as a professional bluing job. Though the bluing on some AXA QC tool holders I machined about 18 months ago still look nice. Some trial and error involved, but it is not difficult to get a deep blue or purple oxide coat.Working on my boring bar holders. Getting closer to finishing up. Just need to drill and tap the set screw, and adjustment stud holes.
Also using the toaster oven to heat sink the parts to give them a finish View attachment 262463View attachment 262464
I used a BBQ to heat the steel and then dropped it in used motor oil. The BBQ will heat to higher temperature than a toaster oven. Very nice even bluing.I like the toaster oven idea. I use a single 750 watt hotplate; put the parts on it and cover with a remnant from an aluminum pie pan. I use a spacer like a bent piece of copper sheet to keep the work-piece off the heating coil. Very crude, but it's easy and it works. With something like a chuck wrench, it takes ~10 minutes to produce a nice, deep blue color. This oxide layer looks nice, but it is not as thick as a professional bluing job. Though the bluing on some AXA QC tool holders I machined about 18 months ago still look nice. Some trial and error involved, but it is not difficult to get a deep blue or purple oxide coat.
