- Oct 14, 2013
- 1,030
Installed the solar panel on our First Robotics storage container!
Sent from my SM-G892A using Tapatalk
what robotics container? You working on something with a crew of smash em robots?Installed the solar panel on our First Robotics storage container!
How do you like your ToolMaker? What would you rather have if you had a choice?Hanging TEN...
I have a piece of Hot rolled that I had ground long ago, I decided I needed to try it to do what I needed to. I think it's 3/8... well it holds well on the mag... this is a coarse pole mag, which they say holds better than a fine.. I don't know, I don't have a fine pole, but it worked.
I was able to grind using the spindexer and my 5c-ER32 adapter. I will use this more frequently, but I will probably put mounting holes in the hot roll to screw into the spindexer... Less to knock into. So I just enlarged my grinder ... I'm less worried about my small size ... Grinder that is.
I like it but it is limited. There are 3 things that would make this more usable for me.How do you like your ToolMaker? What would you rather have if you had a choice?
I'll leave that for others to chime in on... I don't know.Thanks for the input. I am researching surface grinders, as it is one item that is missing from my shop. I want to get a high quality machine, but not too big, that's what I like about your ToolMaker. Any other small grinders that I should research ?
What year is the 911?Safety shields where gone... and it had a broken support... Figured I would install the wire wheel where the support is missing...
One of the light bulbs was blown out... I replaced both of the light bulbs for LEDs.
The sticker!?? Hahahahah... I have a few from the other project that I am working on...
‘67, ‘81, ‘91What year is the 911?
I was a parts manager for a Porsche Audi dealer a long time ago.
