Today’s little adventure was coming up with one of these. A pin puller (pusher? driver? extractor? gizmo?…) to get a tiny split pin out of the rear end of a 1961 Elna Supermatic.
There are a few machine designs that made use of a rubber friction wheel or friction “pulley” as it’s often called to transfer power from the motor to the sewing mechanism and the Elna was one of them. Trouble is, as the machines age and especially if they site unused for great lengths of time (ie: years), the rubber can develop a flat spot where it rests against the hand wheel. It doesn’t kill the machine, it can still sew, but it makes a rather disconcerting thump-thump-thump-thump-thump as you step on the gas. Kind of like those minus 35 degree mornings when the tires on my Dad’s big Buick got rolling for the first time. So gotta replace the friction wheel.
Of course it’s not real easy to get at and everything is small. I measured the split pin as best I could at about 0.090” and built from there. I’d seen someone else’s version of a similar design in use and thought it was pretty clever so I used that as my starting point. There’s nothing really special about the actual machining — I just used a scrap of 6061, a #10-24 machine screw, and a 5/64” drill bit in the end as the pusher.
And it worked great! With hardly more than finger pressure the split pin started easing out the other side until it was completely clear and I could lift the pulley. That is until it ran into the aluminum casting right above it! Grrrr! This is kind of like those car stories where you have to drop the whole motor to change the oil filter but that’s exactly what I had to do — flip the machine over, take off the belly pan, disengage the speed control linkage and drop the motor by an eighth of an inch. Goofy.
Anyway, it worked and it got the pulley off. You should be able to see the flat spot just between my fingers. Coming up with a new one will be for another day. Replacements can be had although I’ve heard the quality can be a little spotty not to mention kind of expensive. I’m going to try casting my own out of some Shore A60 silicone and see what happens.
Thanks for looking!
-frank
