- Oct 16, 2019
- 7,027
Well I’m afraid this isn’t exactly a scintillating project but I haven’t spent much personal time in the shop lately. My industry was in the “first wave” of re-opening after COVID shutdown so most of my energy was coming up with engineering controls and product sourcing for work. Amazing how much juice that type of thing can suck out of a person!
But, back to the job at hand, I have one of the small commonly-available 10-ton hydraulic presses — a bench model much like this one:
I don’t use it terribly much, maybe half a dozen times a year if that, so like most of my other equipment I need to have it stow out of the way when not in use. So I scooped a second-hand machine stand off our used marketplace here and channeled it some to bring the depth down to about 12”.
Then I put some wheels on the legs — these are the cheapie solid rubber things you get for two dollars and change at the hardware store. I don’t need this thing to steer, just to roll in and out from the wall in a straight line, and not for any great distance either. I mount the wheels sideways onto the legs so I can keep the frame as open as possible at floor level.
After that I snipped off about 4” from each end of the base pieces on the press itself and bolted it down to the top of my wheelie stand. The most awkward part of this whole affair seems to be the hydraulic hose which, no matter where you try to put it, seems to be always straining to be somewhere else. The angled side mount appears to work the best for me so that’s what I did.
So far it does what I want and tucks cleanly out of the way when it needs to. I may make it an inch or two higher but for now I’ll try it the way it is. That would also be an excuse to redo the two MDF strips which I ham-fistedly counterbored way too close to the edges. As always, thanks for looking!
-frank
Hah! You beat me to that stand! Good on you
