POTD was making a different cart for my small Harbor Freight sand blasting cabinet. I threw it on a 16 x 30 cart with a piece of particle board under it to move it around. Had a dedicated water filter laying on the bottom of the cart as the air from my compressor was wet enough to make the media stick and clump together. The cabinet leaked a fair amount of sand when in use from underneath. My "elegant solution" was to cut some priority mail boxes and slip them under the cabinet to contain the media and keep it off the floor.
$100 HF sand blaster on a Craftsman 16 x 30 cart
I picked up a fair amount of Creform tubing off Craig's List a while back. Plan was to make up a cart for the blast cabinet.
I had some 6 mm thick corrugated polycarbonate sheeting left over from another project. Figured it'd work for a shelf at the bottom of the cart. Cutting thin material on the table saw can lead to a lot of chatter. The blade pulls the material down into the space between the blade insert and the saw blade, then the material snaps back up. If you're not careful, it can even fracture the material (ask me how I know). I use a zero-clearance blade insert when cutting thin or flexible material, takes the chatter down to nothing.
Stock Craftsman blade insert and a composite plastic one from The Woodworker's Supply of New Mexico
As long as the cabinet was off the base, figured it was a good time to look for the leak(s). Pretty much the complete bottom where the funneled media reservoir meets the sides showed evidence of dust, especially in the corners. I dumped the media, flipped the cabinet on its top and shot a tube of silicone caulk to seal it up. Also made some plywood sides for the particle board base and Roto-zipped a hole in the bottom to access the media drain at the bottom of the cabinet.
Underside view. So where does it leak? About everywhere . . .
Cut a hole in the bottom of the base to access the media drain. Didn't show it, but shot one screw in a piece of sheet metal that sets over the hole. The metal covers the hole and can be swung out of the way from below to get to the media plug.
Another project was changing the internal lighting. I bolted in a fluorescent light fixture years ago, figured it was time to upgrade to LED's. Plus improve my wiring "exit strategy".
I routed the wiring for a light fixture through a vacuum port on the side of the cabinet and closed it off with duct tape. . .
Drilled and tapped some mounting holes for the LED light fixture brackets. Highly accurate Sharpie marker layout through the previous light fixture drilled holes in the cabinet.
LED's in place.
My not so elegant solution for routing the LED fixture wires out of the cabinet was to make a rubber bung to plug the hole. Used a hole saw and a circle cutter on the drill press to make a bunch of rubber disks. Didn't show it, but made a Delrin washer on the lathe for mashing on one end. Plus an aluminum plate with a tapped hole for a bolt to mash the assembly together. Yes, not my cleanest fix but it works.
Cut the rubber disks on the drill press
Finished stand.
Waiting on some inside lens protectors from Amazon before seeing how well my caulk job did on the leaks. Best part is it freed up a 16 x 30 cart for other uses in the shop. I love those carts for transporting tools to the job, keeps me from leaving tools in and under things.
Thanks for looking,
Bruce
