2020 POTD Thread Archive
MK2 magnetic coolant mount. M5 captive nuts pressed into the bracket, then the bracket held into the switchable mag base with an M8 bolt and washer
431E8442-EEB1-418B-A72C-01876CD78EA5.jpegAE744391-12BE-4C40-B430-C13C43351F32.jpeg89D9C351-57A7-461C-B06B-4EA3D01767AB.jpeg28F0E401-D140-4285-BDC2-1EEFDA9C0607.jpegED098B1C-3275-419A-9F46-FF8D3F89DB25.jpeg1EDB6543-9D95-4370-BCB9-ADBA13736D78.jpegA6D0D619-89C1-48F7-8FDF-4DDF255BC7E8.jpegE9CAEA54-0D5D-4AD0-AD0C-BC775757E574.jpeg
Seems much more solid. I might mess with the orientation of the mixer on the bracket... it’s not a very long print if I change things. :)
And the end result. Finally no more oil everywhere on the desk
What mill is that? May have missed a thread somewhere about it.
It is an Optimum MH25V
Chinese machine with german branding
In general quite decent built with a few exceptions which must be taken care of. But it is well suited for CNC conversion.
I picked up some more thread bobbins for my old Singer recently only to find that the modern versions don’t seem to fit the bobbin winder properly. Either the side plates are pressed onto the barrel crookedly or the sides are dished excessively, but the long and short is that the bobbin ends up slightly narrower than is needed for the winder to function. Hmmm....
The bobbins are cheap — like fifty-cents a piece — but of the ten that I bought none of them worked on my machine so it wasn’t even an acceptable average. So I came up with this two part jig that grips the bobbin snuggly and squarely by the barrel and allows me to press the sides in plane with each other. And, if needed, a few more presses on the sides can reduce the amount of dish and make clearance between the sides effectively wider.
It works great, and in less than two minutes per bobbin it’s super fast. My jig is 0.350” thick and I need between 0.370” and 0.375” between the sides, so a pair of feeler gauges at 0.373” allows me to sneak up to final size.
Perfect fit. Thanks for looking!
-frank
POTD was wiring in a Millfast Products remote control panel to my Tormach. The previous owner of the mill had a full enclosure and used the ESC key on the keyboard for an E-stop switch. It works, but I prefer a big red switch to hit. I decided to mount the control box to the lower RH side of the front door. The doors can swing open, so plan was to route the wiring up to the hinge of the door, then around to the back of the mill and into the enclosure/controller.
The doors on the enclosure can be removed, so needed a way to remove the Millfast box from the swing door as it's hard-wired to the controller. Ended up screwing an aluminum plate to the door frame using a couple of Creform brackets. The plate has a couple of 1/4"-20 tapped holes for mounting a second aluminum plate screwed to the bottom of the Millfast control box. I could have mounted the adapter plate on the control box to the base with a couple of 1/4"-20 cap screws, but figured I might as well make some thumbscrews and single-point thread them with a new Aloris No. 8 threading tool holder.
Chucked up some 1/2" brass and turned a shoulder to 0.249"
Used a parting tool to relieve the thread at the base
First scratch pass and verification it's at 20 tpi
Last pass
Verified the thread was at the target 0.2175" pitch diameter
Knurled
Parted
Made a second thumbscrew using a carbide insert
Made one screw with a brand new Aloris threading tool and a second with a carbide insert. So which do I prefer? Pluses and minuses for each. The Aloris tool is wider, so I was just about hitting the base of the screw at the end of the cut. The thread quality with the Aloris tool was better than the insert. However, the Aloris is brand new and sharp, the insert in my threading tool has probably cut 50 threads. The jury is still out, need to pop on a new carbide insert and do some better apples to apples comparisons.
The Millfast control box E-stop switch has to be wired in series with the Tormach controller E-stop switch. Not a big deal; route the cable from the control box to the side of the Tormach controller, remove an access plate and replace the plate with one provided by Millfast. I was starting to doubt my dexterity as I got one screw in the new plate, but couldn't get a second one in. "Oh, can't be old me and my hands full of thumbs?!?". Well, it WASN'T me for once. Maybe Tormach has different hole patterns on the controller access panels, but the Millfast one wasn't even close. I made a new plate from 0.050" stainless.
Millfast plate on the left (control box wire routes through the center hole) and the stock Tormach one on the right. Millfast holes were off by about 1/4", though maybe Tormach has variations on their hole pattern. My original plan was to punch a hole through the center of the Tormach plate (hence, the center punched hole), but went with a new part instead.
Punched a 5/8" hole in some 0.050" stainless
Punched the 4 screw holes with a Roper Whitney No. 5 punch. Trimmed to size with a bench shear.
Fool me twice. . . checking alignment of my plate on top of Tormach's plate
Millfast control box mounted to the RH door. I routed the wire to the hinge of the door, so can still swing the door open without tugging on the wiring.
Aluminum plate fastened to the door. If the door needs to be removed, back off the two brass thumbscrews and set the control box on the keyboard table.
Thanks for looking,
Bruce
There are many (100s?) of tools on my bench specific to the hobby. To put things into perspective, my trains are H-O scale, roughly 5/8 inch between the rails. I use several different "wheel presses" to remove and replace a wheel on an axle. They must run true with no measurable wobble and "in guage", the distance between the wheels.
There is a guage for spacing and my homebrew jig for measuring 0% wobble. Further, drive wheels (steam locomotives) must be "quartered". Meaning the two on an axle must be 90* apart. They don't need to be exactly 90*, they can be 89* or 91*. But all axles in a set must be the same.
Add to that, there are gears, cams, and circular switches between the drivers. I have developed a number of tools, rather fixtures or jigs, for holding such wheelsets in a lathe or milling machine. With many models (most today) built offshore, axle sizes will vary from 0.092+ to 0.125 in imperial and as many more in metric.
To bring the response back in line with the quoted post, I use bobbins for winding solenoids. Aluminium bobbins so they're non magnetic. They have 6mm bores and I use 1/4 inch brass tubing as a spindle. Thus, they must be reamed a few thou. And get bent in the process, more often than not. I have developed my own system for (re)truing the bobbins before applying the wire. These work for me, a lot simpler than what Frank made, but probably not suitable for what he does. It does involve work with the bobbin already on the lathe.
I could go on for hours, but most of my work doesn't fit with the board. And I notice that for every word I type, I must make two spelling corrections. Which means I'm tired of typing and must leave the rest.
3D printed ER32 collet holder and collets for tool and cutter grinder build. Includes square and hex collets
That is interesting. How well has this been working? What do you use it for? I guess you can't use it for any precision work.
As usual, I was working on one project and needed something else. For weeks now, I would be milling something and needed to put a round item in the vise. Small items were no problem as I'd grab the V-Block and get it done. But if it was a big round item, ;one 2" or more... Then the vise just won't open up enough for a V-Block plus a 3" round bar.
So...as I found myself another project which had been put off for over a year now.....Once again my vise just wouldn't open up enough. Seems like this is all I've been doing for over a year now. I took my two big machines out of storage and have spent a year getting them up and running....and then making or adapting tooling for newer machines.
So....as I was trying to fit an Ebay Armstrong B-1 Boring bar holder to fit my lathes....I had to make an adapter plate which will raise the bars to the right hight for my Clausing. Anyway...the big round bar wouldn't fit into the vise. So I decided to make an aluminum vise jaw with a V cut into it. I cut the jaw to specs....cut a 30 degree V into it using a 30 degree angle block....and then drilled the two holes using another jaw as a master.
So...at least Im making some headway. Jaw appears to be on the mark considering I eyeballed everything. I didn't want to waste too much time for this sort of workpiece.
F91D0FB3-F0AE-4F55-B65A-0BF6A58CAB63.jpegD92AB465-F068-4E43-A404-1E9F09CC4646.jpegEA128847-D7C3-45A5-81B6-D7596380C5B3.jpeg3DFF6901-9A0A-4A2A-8C02-44F084246C51.jpeg
