- Jul 29, 2014
- 2,859
I got a good deal on a couple of Kennedy machinist tool boxes stuffed with tools, and after we completed that transaction, the seller just threw in a small craftsman router table with a small 3/4 hp router installed in it. He didn’t want it, but I didn’t need it either...it sat around. Then, somewhere I heard about a “chamfering tool” and thought maybe this could be the platform for it. I took a 12” long piece of 2” angle iron, milled out the interior web radius to a sharp 90 degrees, cut V notches in some Delrin, drilled a hole right down over the router spindle and bolted the whole assembly to the router table. I used a 1/4” HSS end mill in the router and let it stick up slightly through the hole in the angle iron. With the router running, you can slide a block along the V over the end mill, and cut a nice chamfer. Depending on the stickout of the end mill, you can adjust from a very light breaking or deburring of the edge to a thin or wide well controlled chamfer.
I apologize for the video, but I hope you get the idea. I am kind of surprised how well it works. And this really demonstrates climb vs. conventional milling if you run it through the wrong way. This is a block of aluminum run through at whatever RPM a Sears woodworking router turns. Wish it were quieter, though.
View attachment 4783BA3D-EBFC-45D4-96C8-C181AD7D4CF8.MOV
