I didn't post this earlier last week when I had it done. I wanted a proper vacuum advance on the distributor, so I needed the venturi vacuum off of the carburetor. As this carburetor is venturi based, it already had the plumbing, just not the tube/nipple. Many folks drill and tap with a 1/8"NPT and just use a brass nipple from the hardware store, but I didn't want the look, I didn't want to go to the hardware store (anti-social), and I didn't want to buy one. I grabbed some brass hex bar I had laying around from a previous project, and drilled/turned the tube. I made it to match my old carb, actually. It was my first time using a cross slide stop to ensure I didn't bend it and to ensure it was relatively even on the outboard surface.
I cut it off and installed it to the metering panel.
I really had no idea when I started this journey what I'd end up being able to do. For example, yesterday, I needed another part for the car (oil pressure sensor was in a weird place with this "old" replacement engine). I made one, found it was not going to fit, and made another. The first one was drilled and milled, then turned round and threaded.
The second iteration (I was getting tired and didn't grab a photo until I was tapping the final hole) was turned on the lathe, then milled a few surfaces flat until I could get a wrench on it and have one for the adapter.
I'm not quite done tapping, but I'm close. Then I should be able to start the car again and
REALLY tune the carburetor.
