H
Hukshawn
Forum Guest
Register Today
I solved my pneumatic problem I mentioned before.
My boss gave me a sizable bonus from the oak room job (in my "projects" thread), so I found a 5hp 3 cylinder 18cfm compressor on a 60 gal tank.
I promptly swapped out my 2 hp 2 cylinder. Put the new pump/motor on my old Brunner tank in the garage, and piped in the new-to-me tank outside.
So, I went from roughly 10cfm 60 gal to 18 cfm 120 gal! Lol. Prettttty sure I'm not gonna have any issues with running sanders or spray guns anymore.
The second half of the setup is a controller.
I like leaving my compressor powered and charged. When I want air, I want it now. I don't like waiting for it. Especially if I'm downstairs in the woodshop. Just grab the air line and know I have a full charge of air. I always had the airline to the basement on a shut off outside in the garage because it's an additional 50' of hose, and now with the pony tank, that's a lot more piping, many more places to fail.
So I added a timer controller. It will cut the power if the compressor runs more than the allotted time. So if a pipe blows it won’t run all day and burn my house down...
Peace of mind.
I also did a leak test yesterday/over night. Pony tank lost zero, compressor lost 10psi. Found some leaks in the pressure switch. Changed the setup and re did the pipe fittings to proper instead of hobcobbled. We will see how it looks tomorrow.
The 120 gallons fills from dry to cut off at 135psi in 10 mins 20 seconds. AND i slowed the pump down to its lower speed. 1050 rpm (18cfm) from the 1200 it was running. That's an incredibly fast fill for me! From cut in to cut off its like 50 seconds. Hahaha.
I piped all the inlets to outside to reduce the noise in the garage. Works great. Between the houses you can hear the "shuk-ka-shuk-ka-shuk-ka from the mouth of the pipe. Lol. And I bolted rubber pads under the pump and under the feet of the tank to reduce how much it shakes the house.
Here's the outside tank.... And yes, we're having a god forsaken ice storm currently....
Currently I have the pony tank piped with PEX. Its good to 160 psi at 74*f. Eventually I'll pipe it in 1/2" black iron and put the tank on a cement pad, bolted down.
All buttoned up. I put an indicator light on the front so I can see at a glance if it faulted.
Peace of mind.
