L
Lordbeezer
Forum Guest
Register Today
Heard that..
Finished up dating my tapping machine. I made the machine years ago but wanted to up date my tapping machine after using it the other day.
I
I got the same pennys drill stand. Another project in the future. Thanks for the idea.
I have also been messing around with the RF30 mill drill. Some things that have bugged me since I got it a while back are the spindle height locking knob and the quill lock handle. Both use rotational movement to engage /disengage or apply a clamp action. I prefer an engagement that's either on or off. Plus the spindle height locking knob hasn't got much space for ham sized fists to grab it.
So the quill lock handle (RHS) was replaced with a locking lever (LHS).
Down is unlocked.
And horizontal is locked. The spring makes sure the clamping "wedges" move apart when compression is released.
The spindle height lock was also changed to a simple lever mechanism.
Same arrangement as the quill lock, down is unlocked, horizontal is locked.
The mechanism to change between coarse and fine down feed is quite simple, its just friction using two 'cones'.
The black male piece clamps against the silver female sleeve to lock and engage the fine down feed.
I cleaned the mating faces of both "cones" which also helped the positive enage/disengage action.
Quite happy how it all turned out.
pete
