Carrying on with this project (
https://www.hobby-machinist.com/thr...you-make-in-your-shop-today.67833/post-576905)
Made the second block-off plate:
made a new plate for covering the original inlet port as the one I made needed a couple more rivets to hold the cover flat against it, but there wasn't enough overlap to do it, reassembled the cover and installed it.
Then, fashioned a handle for lifting the engine and cut the hoses to fit:
This will teach me to leave "stock" lying on the ground next to where I park my truck:
Now, the only remaining tasks are to:
-make some wear plates for the nozzle
-make some brackets to put on the bagger cover, to hold a long tube/nozzle for vacuuming in harder to reach spots, like flower beds
-determine the best spot to locate the rear wheels, so the unit has good balance both when the engine/blower is installed and when it is removed
But it looks like tomorrow it will be a snow removal day:
