Very quick job today.
6 rods in stainless. 12mm dia, 30mm long with 20mm turned to 6mm and threaded M6x1
One side to be milled flat so I can drill and tap 2x3mm holes for fixing some flat brass strip to.
This was the third design I eventually decided upon.
Turned the 6mm dia, threaded the end m6, parted off to length, repeat till all 6 were done.
Then I reset each rod and rounded the end with the curved part of a router bit
Then mounted each rod in a tool holder, set the height and using a 10mm end mill to face off the length of one side. Repeat again.
Start
finished in one pass
The 6 finished parts with the router bit I used to round over the ends.
These will eventually hold the spiders on the giant binocular.
Start
