T
TOOLMASTER
Forum Guest
Register Today
brass too..just look at the boogers on your ground clamp
Got the enclosure back plate and standoffs for the control system Mark (mksj) is designing and building. The enclosure will have a clear door/face and the aluminum I had on hand was rough in terms of finish, so I decided to spend a little time to make it nicer. The 2" standoffs where made using the newly acquired 5C chuck. I really enjoyed the close work without the threat of a large rotating chuck. Parting was also uneventful as was power tapping 10-32. The enclosure will be mounted to the wall behind the lathe while the more complicated control system will be hidden inside the machines cabinet. Mark has been very generous with his knowledge and time.
Hear you can see the condition of the aluminum finish prior to "engine turning".View attachment 122613View attachment 122614
Facing,drilling,tapping and parting using the 5C chuck.View attachment 122615
The finished product.View attachment 122616View attachment 122617
New button panel for the front of the lathe. Punched the holes in less than 60 sec. on iron worker.View attachment 122618
Thats it for now.
not sure i would put holes where chips can get in
Thanks Mike, I have never used a 5C system before, and can't believe it took me this long, but then again, I'm alway learning new things. It made thing quicker and safer IMO.Looks amazing Paco, but I'm a pushover for engine turned items. I've been trying to save up for a 5C chuck for my 13x40 lathe as well. Unfortunately it keeps getting pushed down the list.
Mike.
