2016 POTD Thread Archive
I'm with you on that, Toolmaster. I hate doing multiples. I had to build 20 drawers when I made my kitchen cabinets. It was torture. Especially varnishing them — three coats on twenty drawers.
I learned about boring bars in my shop recently. On my bike stand adapter, I had to bore out some 1.5" tubing to make it fit two different size components. The only thing like a boring bar I had were the ones that are supplied with a mill boring head, with brazed carbide inserts. They work ok in the boring head but never very well on my lathe.
I dug in my stuff and found an indexable boring bar I had purchased years ago after I got my first lathe. It was a 3/8" indeaable bar and wasn't up to the task, chattering and squealing and producing a horrible finish on the inside of the tubes.
I checked the boring bar tool holder that came with my AXA toolpost and saw that it would hold a 5/8 tool. So, I ordered one from Shars. It got here today and I tried it out on a piece of scrap tube tonight and the difference is night and day. I can now bore large smooth holes.
Then I discovered that my boring tool holder will also accommodate a 3/4" bar, so I ordered one of them, too.
Not having much experience with boring bars, I have a question. It seems like if I set the carbide cutting edge at the center, that it would drag. The CCMT insert is pretty thick. I mounted it a tad higher and got very good results. Is that generally true with indexable boring bars? I was boring a 1.25" ID tube. Maybe on a larger diameter it would be ok on center?
Yesterday, we serviced my old truck and discovered that the sump plug had basically been destroyed. Needless to say, no one knew who removed it during the previous service, so I decided to make a new one, using a piece from a 42mm scrap pump axle. I also got to use my recently purchased indexing head for the first time:
I like it but feel that you should have left it as round bar so that at the next service they can get a better grip on it with their monkey wrench . :grin:
Funny you guys should mention multiples. This is what I was doing this afternoon. Seems the professional machinist missed a change and made some parts (end caps) with the wrong ID. Luckily my Atlas/Craftsman 12" lathe came to the rescue and turned down the 38 bushings to fit. Got a little boring but it was nice to see all the shiny parts when done. These parts are for a product we are manufacturing that is used on tiller steering outboard motors to dampen and reduce steering torque.
i could use one of those on my horizontal bandsaw..
Believe me they actually did use a monkey wrench on the original. It was supposed to be removed with a large allen key, but they probably couldn't find the correct one. I actually considered machining the new one for an allen key as well, but I think this is better.:eagerness:
I could never be a production machinist...making multiples drive me nuts:eek:
That's why I became a toolmaker instead of just a machinist. Once I even got let go from a place because I refused to work production for a couple days. They wanted me back after about a month. I told em I would only come back if I never had to run production. Went back as foreman of the shop and then went into engineering designing special machinery.
Depending on the parts being run, multiples can be a good time for reflection on all that is good and right in the world of machining.
Drilling cross holes in screws for safety wire, with a box of 1,000...perhaps not so much.
