I have seen Colchesters of this era (same as mine) in both the light and dark greens, mine is dark green like this one!
Phil
One thing you might try if you want to "save" the taper you made is to cut off the small end, then drill & tap into it and insert either a long setscrew or a bolt with the head cut off. The screw can be set to whatever depth lets you to fully engage the taper, while allowing the tailstock screw to eject it. I have several Morse taper accessories with such a screw, and they work very well.The next taper turned out to be a really snug fit and a very nice finish that I was happy with. However I turned it down a tad too far, the large end is undersize. As I made this one with a tang on the end it doesn't engage properly as it slides too far into the 3MT socket. So anyway, tomorrow I'll make another one.
Looks good for first time doing a Taper.
You might try making a Taper attachment next. They are pretty easy to make. I think I might have used $50 in materials for it.
I made mine out of 1/2" x 4" and 1/2" x 2" Aluminum and it bolts onto the backside of my Craftsman.
Works great and I can make any Taper with it.
what are these keepers you speak of? like set screws pushing on the threads?
even so I would be a little wary of using a parting blade in this manner given the high pressured nature of that tool.
