- Nov 26, 2015
- 5,166
Yeah the drill method was tempting, but then I would have to stick it somewhere when I am not using it. And Murphy's law would come into play when you go to use it and the battery is weak and needs to be recharged right in the middle of a project.Tee-hee! Sounds like you went through a whole lot more work adapting the power feed you bought ... and I'll bet it was just a tad more expensive than a battery drill woulda been
Well, I suppose that might be a factor ... but I thought the idea was to remove the drill when you weren't using it to move the knee.
Anyway, all kidding aside, that's a really fine looking job you did. Congrats!
PS - If you leave the crank in place (as shown in your last photo), will it spin when you use the power feed?
PS - Might you be able to rotate the power feed about 90º on its mount, so that the controls face upward? That might make it handier to use (unless it interferes with something else).
The handle slides off the stub shaft I made and hangs on the end of my table.
