- Apr 21, 2015
- 894
It looks like your treadmill motor for your drill press conversion had the flywheel on the same side as the drive wheel, right? Mine are on opposite sides. The existing drive wheel is about 1" diameter aluminum, 1.5" wide, poly-v. It weighs about 5 ounces. Not much there to work with. I suppose I could mount something on the side of the flywheel, but there isn't any arbor left to grab onto so I would be drilling into the face of the flywheel, potentially throwing away the balance it currently enjoys. But with the fan on the drive wheel side (and an apparent press-fit) I wouldn't mind using the flywheel side. The nut for the flywheel came off easily, but the flywheel didn't. It just pulled the shaft within the housing. It wasn't until later that night that it occurred to me that the flywheel may be threaded on as well. I'll see how easily it comes off. That side has a right hand thread, so eliminating the flywheel and using a tap for the drive wheel threading (and having the benefit of a drive wheel that doesn't spin itself loose in use) would simplify things. It just seems like the weight of that flywheel is desirable as, you know, a flywheel. Perhaps I should just make up a new drive wheel for that side that incorporates a new flywheel.
So many decisions...
