I mean, for cripes sake. You don't even need any tools to change a tire! I do have a set of bicycle tire irons, but I worked the back tire off the rim by using nothing more than a section of 1/4" wooden dowel. I did get my tire irons out to do the front tire, just because I could find them.
My make shift bike gantry stand.
Actually, depending on the rim/tire, some of the newer road bikes don't come apart so easily as the "old" style tires.
Not saying you can't do them at home, but it's not like when I was a little spud.
My Giant Seek 2 road bike has thin high pressure tires that have what seems like a death grip on the rims and that's not even a high end bike.
Heck, even a plain old tire pump doesn't fit my Seek2 tire valves. Needs an adapter or a special chuck on the pump. They're called Presda valves IIRC...
They even have tubeless tire now too.
Some bikes have very fragile rims (IE: built to be strong and light, but do not tolerate damage well). I can easily see someone taking something like a newer bike to a shop so as not to damage/bend the rim....or they are responsible for that expensive rim if they damage it.
All comes down to how much you spent on the bike in the first place I'm guessing. Very expensive bikes may be light and strong, but usually easily damaged. I'd want someone else responsible for that damage on a tire replacement.
Of course, if you've spent mega bucks on a bicycle, you probably aren't going to sweat paying someone else to work on it either....
