New urgent shop project.
While turning a part yesterday I heard a clicking sound coming from somewhere inside my cross slide. Then something inside the headstock clicked and the lead screw quit turning. I looked inside and found that the change gear lever had disengaged. I moved it back up, tightened it and fired it back up, threw the drive lever and it popped back out again after a fraction of an inch of travel.
That disappointing series of unfortunate events repeated a few times.
I left the drive lever disengaged and finished the job by manually turning the last bucket full of swarf off my part with great effort and vast expenditure of time.
When life hands you lemons, you can make lemonade that will probably taste like cranberry juice — but only if you don't like cranberry juice. Otherwise, it will taste like something else you don't much care for.
My Grizzly G-4000 lathe is 10 years old and has never malfunctioned before. I was nervous about removing the cross slide. Finally, today I got up the nerve and unscrewed a couple bolts that hold the shifter rod that the lever operates, discovered that the hand wheel secured with a roll pin had to come off too, and removed a cover on the back of the slide so I could see what the heck with a mirror and flashlight. (I still haven't taken the slide off). I discovered that the drive gear that engages the drive screw was missing about 6 teeth. I guess that is what was making the clicking noise.
I have no idea how that gear got chewed up like that. I've known not to engage the drive lever and threading lever at the same time for several months. I don't think it is something I ever did before, but who knows what black sheep have been shoved to the back of my mind's closet. At any rate, it broke yesterday for reasons only the Great Mooga comprehends. I'll not waste energy assigning blame.
I will definitely have to remove the cross slide.
I called Grizzly this evening right before 7pm and ordered a new gear. $20.74 shipped and will arrive middle of next week. Good for them! I hope I ordered the right gear. All those zig-zagged lines on the parts drawing were a bit confusing.
More later...
