B
British Steel
Forum Guest
Register Today
1983.
It's getting some major work done.
I'm in the process of adding a 2002 royal star transmission gear set, vmax rear differential. VMax heads and vboost manifolds.
It's getting coil over plugs and digital ignition.
I'm ditching the old bias ply tires and putting 17" radial tire rims on it. Thats the reason for the green rear rim off a zx7r (modified to hold the spline drive for the shaft) and a 2006 r6 front rim. The wheel swap is the main reason I built the laser alignment jig (needs swingarm work to fit the 180/70r17 rear tire/rim).
Cartridge emulators for the front forks and I'm still working on what to do with the rear. I was working on a zg1400 shock, but I don't think that is going to work out (too long).
R6 monoblock calipers are also going on.
It's getting the later style side paniers in the photo, since they have more capacity than the 83-85 ones.
I'm also chucking on a set of r1 mufflers, mostly because they look kinda cool sticking out under the bags:
I'm thinking of making it sort of a "bagger" for around town use:
Sort of a "honda f6b" concept. Low enough sheild to get a good blast of wind in the face around town (gets pretty warm behind the tall shield at low speeds) and put the top trunk and tall windshield back on for long distance rides. Bagger like the above pic is easy to do. I'll just build a second seat to bolt on and off with the small rear duck tail on it.
Lots of work done, lots of work to go....
I like... Those pipes do look the biz
With the VMax parts, you're really going to annoy the Hardly-Ridables...
I have a VMax, did the wheel conversion (Diversion 900 rear with a 150-70/17 Battlax tyre, Thundercat 600 front and 120-70/17 Battlax), it almost corners like a motorbike...
Also lowers it a touch, good for those of us with Dachshund Syndrome!
The front end conversion needed a little "machining" off the lefthand fork bottom to centre the rim ( left off the righthand spindle spacer and fitted wheel and spindle with the speedo drive in place then measured brake bosses to rim both sides, angle-ground/blued the speedo drive face/filed-to-flat-and-square until it centred) and a turning down of the spacer on the righthand side, the rear end needs a new spindle and the VMax dustshield grafted to the Divvy wheel and new holes drilled to mount it (in the shield, not the wheel!).
Something I really like is that the Thundercat and Divvy wheels are a really good match
Re calipers, I was lucky to find some YZF400R-3TJ four-pots which bolted straight on (same bolt spacing etc., need a thick washer / thin spacer between fork and caliper), big improvement for not a lot of money, but not a common part!
Can I ask a favour, swingarm pivot to wheel spindle distance? I've been thinking about putting a Venture swingarm on my VMax to get a monoshock back end as a possible alternative to modding the original (lengthening and bracing, which would involve a lot of welding and making a longer drive shaft...) - I looked at the Diversion 900 rear end, but it's not significantly longer (uses the same bevel box though with different clearances, so may offer another choice of final-drive ratio? May be worth checking out the FJ1100 / 1200 / FJR too?).
I blew it up running-wot-I-brung, so some serious work required for summer or I'll be stuck with just the ZZR1100...
Dave H. (the other one)
