Industrial grade helmets react at speeds of 1/10,000 to 1/20,000 of a second and have adjustable shades settings of #9 to #13 for welding. Industrial grade helmets also have adjustable sensitivity (useful for low amperage welding) and delay controls to adjust how long the lens stays dark after the arc stops.
Newer helmets have different modes, allowing the same helmet to be used for welding, cutting and grinding. The most recent development is a mode that senses the arc electromagnetically, offering full protection when the sensors are obstructed, as when pipe welding or welding out-of-position.
Avoid auto-darkening helmets that darken with a reaction time of 1/2,000 to 1/3,600 of a second. This is not adequate for industrial applications. Further, cold weather delays the reaction time on all auto-darkening helmets. Higher-end helmets are rated for use down to 14 degree F. However, low-end helmets with slower reaction times may not darken quickly enough in cold weather
verbatim from Miller, auto darks aren't perfect, they are great but they still aren't used in field pipe welding here in alaska, I work oil field and have NEVER seen a pipe weldor in the field or in the weld shop use an auto dark and it's because of the statements above. I said before they are great for in position where there aren't obstructions, and I know my 3M doesn't magnetically sense the arc as I've been flashed many a times when out of position when the sensors are obstructed, enough times I've wanted to throw the helmet across the room
