2015 POTD Thread Archive
Re: POTD got tool sharpener up & running
I recently purchased a used Enco tool grinder and finally got it up and running in the shop. Had to take the table off so I could get it in the door. The base is on casters so it wasn't too difficult to roll in on planks after using the tractor to move it around to the rear of the shop. The cross-slide table was put on a platform (formerly under older computer) to get it in like the base. Had to put a hoisting eye on timbers across ceiling joists so I could hoist the table up to assemble on the base. Of course since the shop is a former house there was a lot of preparation work to get this all done. Now to learn how to sharpen bits and end mills.
Have a good day
Ray
I recently purchased a used Enco tool grinder and finally got it up and running in the shop. .....SNIP..... Now to learn how to sharpen bits and end mills.
Ray
We need pictures :))
It's the tooling that makes the grinder useful. What tooling came with it?
Today, my shop is the kitchen.
I am making up a big honkin' pot of my special gumbo. It's labor intensive, and time consuming, but the end results are *soooo* worth it!
Turned a pilot for a spot face cutter. It's a simple thing, but it's also close tolerance, Ø -.001" to bore and TIR of .0005" (.001" when mounted in the cutter). The tool will be used to spot face secondary sparkplug seats in the heads of my VW aero conversion engine. Main sparkplugs run off a magneto and the secondary plugs are driven by a Dyna 5 electronic ignition and coils. The engine will run on either, or both. We like redundant ignition systems.:))
What time should we show up and do you have enough beer for all of us?
Eh, it'll probably be ready around 5-6 pm. Started at 11 am with cooking a pound of bacon. Put the bacon grease in a little saucepan with a stick of butter, added 2/3 cup unbleached flour, 1/3 cup of whole wheat flour. Put on medium high head, stir continuously until it's the color of a dark chocolate bar. It'll smoke, and smell like it's starting to burn, just keep stirring. Once it's done, pour quickly into a pyrex bowl, set off the heat, and let cool. Turns into a thick goop the color of coffee grounds, and smells heavenly. That's the roux. (pronounced 'roo').
Cut up two pounds of chicken breasts, into about 3/4" cubes. It's best to use a ceramic knife, on chicken that is just a tiny bit still frozen so it is easier to cut. Dump the chicken into a big (I'm using a 16 qt stock pot, and it's barely big enough) stock pot on medium high, and cook through. You'll get chunks and bits of chicken stuck to the bottom, along with a thick carmelized scum in the bottom of the pot. Leave it. Once the chicken is cooked, dump it into a large bowl, set aside in the microwave (not to cook, just to keep it out of the way and people from nibbling at it). While the chicken was cooking, I cut up:
Two big green peppers.
Two huge yellow peppers.
A huge red pepper and a little red pepper.
Two orange peppers.
Two Hungarian wax peppers (a little warm, because my wife doesn't like food too spicy. For myself I prefer jalapeno's)
An entire bag of celery, leaves and all
Two huge sweet onions
Those go into the stock pot, crank the heat to just under high, and let 'em cook. Stir once in awhile, and it gets all that stuck on chicken and baked-on-carmelized-goodness off the bottom of the pot. Keep cooking until the onions have gone translucent.
While that's cooking, cut up:
1 lb of andoulli sausage
1 lb smoked turkey sausage
1 lb turkey kielbasa
Now add two quarts of chicken stock. Due to a supply error, I'll be using one quart of chicken, one of beef.
Dump in the cut sausages, add water if necessary until the level is right around the top of the ingredients. Add a several heaping tablespoons of roux, a big tablespoon of crushed garlic, some salt, pepper, paprika, ground red (cayenne) pepper, and stir it in good. Let it come to a gentle boil, and cook for about 1-1.5 hours, until the sausages are mostly done. Dump the chicken back in, cook for another 45 minutes to an hour, stirring occasionally. And yes, that's 5 lbs of meat and about 6 lbs of vegetables, plus stock. Takes up a bit more than half of a 16 quart pot.
Season to taste with salt, pepper, and ground red pepper. Serve over jasmine rice with a good cold beer on the side, maybe some deep fried breaded okra as a side dish. I generally make as big of a batch as I can, because it freezes really well, and it's quick 'n easy to make meals with the frozen portions. Just throw in a pot with a splash of water, when it's mostly thawed get some rice started in the rice cooker. by the time the rice is done, the gumbo is hot and ready to go.
Right now it's on the stove simmering. The aroma is making me drool, and it's driving the dogs insane. It's got about 30-35 minutes till the chicken goes back in, then it'll simmer until the chicken is just short of falling apart.
There's only a few things I can make really good.
Gumbo.
Sauerbraten.
Coffee.
Ice.
Two orange peppers.
Gumbo.
Sauerbraten.
Coffee.
Ice.
So how much to ship a quart to CT ?
Today I took the head off one of my Honda GX340 engines.....milled 0.065" off it, and opened up the ports. The mill wasn't 100% trammed in as you can probably figure out by the machining marks. I straight edged the head, and it's less than 0.0005" out. That's the thinnest feeler gauge I have in the collection. Good enough ! :) I also put a new carb on it, as the old one was taken apart by the previous owner, and half the pieces were missing. I filled it with super unleaded, and it started on the first pull. :) Yay....now to pull the governor out of it and build another long tail mud motor !
Having lived in Lafayette Louisiana, I approve of this recipe :)
Funny thing is, I was born in Tennessee. Moved to Florida when I was 7-8, and been here since. But I absolutely love Cajun cooking. While my digestive tract would beg to differ, I love spicy foods. Bring on the mudbugs, taters and corn! The Holy Trinity (onions, celery, and all peppers) is a dang good starting place for any recipe. Sweat the onions clear, then add the meat, stock, and roux. Boil till tender, serve over rice or mashed 'taters.
The Sauerbrauten marinates for three (3!) days, turned once a day, in red wine, rice, and cider vinegar that was brought to a boil with salt, pepper, whole cloves, and bay leaves. After that, I dump the marinade into the pot (strain out the leaves and cloves), add chicken stock, and boil until fall-off-the-bone tender. After 1/2 an hour, add the Holy Trinity, carrots, and fingerling potato chunks. Let boil another 30-45 minutes, then remove the roast, serve on a pile 'o mashed 'taters, smothered in gravy and veggies, with a big 'ole chunk of roast on top. Apple-beans (apples, bacon, green beans cooked in vinegar) are a fantastic side, with a good dark stout beer (Guinness recommended).
*DISCLAIMER* I take *NO* responsibility for the nuclear-fallout level flatulence that follows these recipies. Or any gastro-intestinal distress suffered by anybody who partakes of these dishes. Eat at your own risk. Blaming it on the dog will result in a trip to the vet to see if your dog is a zombie, blaming it on SWMBO......that won't end well..... If you're of the mindset to recycle *everything* you could probably light it off and cut through 3" plate steel as fast as you can scoot. :lmao:
Rice is cooking.... here's the gumbo!
Update - On top of rice -
