i have a handful of odd shaped carbide inserts that appear to snap into some type of holder. i thought i would like to see how well they cut with my 12" craftsman lathe so i took a old china tool stock, the kind with brazed carbides that are cheap, and milled an area to hold the new bit, drilled and tapped a 6-40 hole for a clamp i made out of a small chunk of m.s. and put it in the lathe and tried to cut the threads off a 1/2" grade 5 bolt. no reason, just wanted to try it. well, as the tool was traveling down the threads and taking them off, i could see the tip of the tool flexing up and down. crap, i think i did;t leave enough metal to support the tool, and of course, taking a light cut with carbide is not really pretty either. i probably should stick with has or cobalt and just keep grinding as needed. . .
View attachment 93185View attachment 93186View attachment 93187
