- May 24, 2012
- 394
You said mini, but I didn't expect that small!!
Bernie
I can kill a ant with this!
Bernie
An mini Baseball bat to test my ability to do small diameters.
The part came out great but I'm just wondering why you didn't just make it from one piece of bar stock.I made another rifle quick down screw, this time for a Marlin 780. I decided to make it in 2 peices and to try and get the fit between the 2 as tight as possible. I started out with a 5/8" by 2.5" grade 5 bolt.
I machined the flats off to a diameter of .900" and faced it off flat.
Then I center drilled it so I could use a live center while I knurled the head.
I drilled and tapped it to 5/16" 24 tpi to fit the rifle then counter sunk the hole to a depth of .200" with a 15/32" drill bit which gave me a hole diamter of .4670". I used and old 5/16" fine thread bolt from my collection and turned off the flats to a diameter of .4761" for a .0001" interferance fit.
I threaded the 5/16" bolt into the handle head and prepared it with red loctite. I heated the head up with my heat gun to about 500 degrees then quickly threaded the bolt in until it stopped at the bottom of the countersink.
The I chucked it back up in the lathe and faced it off and put a non-directional finish on with a 3M buffing pad.
It turned out pretty good but you can still see the parting line between the 2 pieces.
Ah, I had a feeling that it was a bit of an adventure. I know it takes a lot more skill and patience to do it the way you did it. Again, great job.I have a bunch of bolt hardware that was free and I'll never use for anything else. I didn't want to go out and buy material whe I have free stuff to use.) Plus I wanted to see if I could fit the 2 parts together with no visible seam.
