Looks great, and is functional, wonderful having things where you can get to them when you need them.I finally did something for just me. the neighbor had a bunch of walnut that he sawed up into planks and boards, and I just shamelessly needed to have one for something or other. well, this is the "other" for me. sawed to length, ran it thru the planer and drilled a few holes in it, made some brackets that slip between the mill and the stand and installed it. the poly varnish finished it off quite nicely. not fancy just function.
View attachment 55083View attachment 55084
Well, today I decided to try to cut a large 1" steel plate so I can strengthen my milling machine back and table (trying to reduce vibration to as close to 0 as I can). Decided to prop the plate up on buckets and use a grinder to cut it (ran out of o2 for the torch and its too think for the plasma cutter). Got one end on a bucket and as I lifted the other end it dropped and smashed the two middle fingers on my left hand (really something I dont ever want to repeat). Normally this sort of thing only hurts for a while, but I guess the fact the plate is 160 lbs its going to hurt for a long time Did manage to grind about 1/2 way through before giving up for the day and soaking my fingers in cold water. With any luck I didnt smash the bones, but so far I can still move them pretty well. Willl see what they are like tomorrow.
I know what you mean, you can buy a new rotor for just a bit more than turning one, of course it's chinese, but that's the way things are now. I see brake lathes on craigslist all the time in the Detroit area. It will be a lost art too.Back when I bothered with drums and rotors, i got so aggravated that I bought a brake lathe. They're built for it and make the job simple. Not pleasant, but made for the job, so no real bother. And around here, it seems everyone it quitting the brake turning business anyway, so there are several lathes for sale. I won't even do my own on my machines.
