Small point of clarification: chains don’t stretch, they wear.Finally bought some 20w50 oil, it was difficult to found. Seams parts stores and gas station cary only the lightweight oils for newer cars, and the prices are 3x more expensive. So i went to the tractor supply, they only have big packaging so i had to buy 10L jug. Refitted the drain plug, installed a new german oil filter fill the engine with oil and test drove it. Now it drives much better and its a bit more rev happy, i still don't know why the timing chain got so much slack. It's hard to imagine such a biffy chain to have stretched.
View attachment 439080View attachment 439079
what happens is each pin wears the bore in its side plate and roller and that creates a small amount of play. Add this up over 50-100 odd links and the overall effect is the chain gets “longer”. Guys often misinterpret this as the chain “stretching”.
so if you were running the wrong oil, or not enough of it, the pins wear faster and the chain elongates (or stretches if that makes more sense to you) faster. How robust/thick/heavy the chain looks is pretty much irrelevant. Its how fast the pins and thier bores wear that kills a chain.
It doesn’t matter if its a timing chain in an engine, a drive chain on a bike or a power transfer chain on a piece of agricultural equipment. It’s all the same type of wear. Wrong grade of oil or a shortage of oil just accelerates that wear.
My 8x8 Argo has somewhere around 70-80 FEET of #50 double roller chain driving the wheels. You learn how chain fails pretty quickly when you have to deal with that much chain in one piece of equipment….
