Today to and back from work i could feel the little niva pulling to the right, check the tire pressures they wore ok. Then i pull it in the small garage check the alignment, i use two tape measures to check it. It was fine, then i lifted the wheels one by one and found the drivers side had lots of free play. And the passenger side was dragging the brakes, so i took it to the big garage, put it on jack stands removed the wheels and found the dust boots on the new brake calipers that i installed less then a year ago has fallen apart. I had 2 new seal kits on a shelf so i changed the seals and clen the corosion. On the drivers side it was the same so it also got new seals and i tighten the wheel bearing on this side. This is my first repair on the front end scene i rebuilt it last and got me thinking i don't have any tools in it, so i went and bought this ratchet wrench set, prices on tools have gone sky high.
