1/6th scale 1890's 30ft navy steam cutter (live steam)
Thanks for that great explanation
playing with more copper,, started work on the exhaust header pipe,, besides the engine the boiler feed pump exhaust into the pipe, It also will have a fitting where the vacuum gauge attaches.. cero-bend used to get nice bends, left the cero-bend in the small piece while milling the joint end with a ball-end mill. got the main joint soldered, seems to have got it correct..
had to get a little inventive with the mill clamping,, gauge pipe and feed pump exhaust port added, now for clean-up and copper plating..
found some info on using epoxy as binder to help make small casting cores less fragile, made a mold of the core and added just a small amount of epoxy to some delft sand/clay,, looks like it worked, the core still scrapes and sands well, but feels strong.. maybe a day or so before I make a casting attempt..
