1/6th scale 1890's 30ft navy steam cutter (live steam)
tghsmith
Feb 10, 2019
304
this project started 10 years back when I found the plan book for navy boats 1900,, 2 years ago I came in contact with a full scale steam expert who had the engine and engineering plans.. the 30ftr and 1/6th scale was decided on because a Stuart Turner compound twin engine block is very very close in size.. brass lost wax castings have been completed to convert the ST engine kit to the navy type engine.. while waiting on things, work on the hull brass and fittings has been started.. hope fully the arrival of my LMS 3990 mini mill will speed things up in the engineering dept..
did some mill work today,, after making a set of support blocks the casting for the engine bed was leveled and trued.. frame mount pads and crank bearing surfaces machined along with the upper bearing blocks,, valve chest and covers received more work .. this maddness might work..289062289063
machined up a jig block to build the engine frames,, added some bolt holes and made clamps to hold everything in place will milling and soldering.. still need to make the truss rods.. waiting on a hardware package from the UK.. might as well keep it all the same tread type..289497289498289499289501
Looking good! Will this actually run or is it a model?
needed to work on some small (and round) parts,, clamped my unimat SL's milling table to the mills table,, used the spindle threaded t-post to mount a 3 jaw chuck,, what would have been an iffy job on the unimat was done in about 2 minutes..( the part is back on the unimat getting the final lathe 289672work done..)
